So to add on this point, I found out the best way to spray the adhesive on the rod is the following steps:
- Spray adhesive on a paper towel
- Take the pump head off
- Actuate the pump and run the paper towel (w/ wet adhesive) onto the spinning metal rod.
This helps minimize the mess and the coating a bit more controlled.
