# Issues with Populating Active Calibrations in Experimental Setup Dashboard
**URL:** <https://www.evolver.bio/t/issues-with-populating-active-calibrations-in-experimental-setup-dashboard/478>\
**Category:** Electron GUI\
**Created:** [August 28, 2023, 8:51pm UTC](https://www.evolver.bio/t/issues-with-populating-active-calibrations-in-experimental-setup-dashboard/478 "2023-08-28T20:51:10Z")\
**Posts on this page:** 1\
**Showing post:** 4
<div class="post-metadata">
**Author:** ![esouth](https://avatars.discourse-cdn.com/v4/letter/e/da6949/32.png) [@esouth](https://www.evolver.bio/u/esouth)\
**Post date:** [September 1, 2023, 1:51pm UTC](https://www.evolver.bio/t/issues-with-populating-active-calibrations-in-experimental-setup-dashboard/478/4 "2023-09-01T13:51:54Z")
</div>
Thanks, Brandon. If anyone else encounters a similar issue in the future, here’s what worked for me:
1. **Updating the `calibrations.json` File** : I first referred to a [previous post](https://www.evolver.bio/t/evolver-wiki-software-release-2-0-0/383) and used the calibration code snippet provided there. I copied and pasted this snippet into my `calibrations.json` file located on my Raspberry Pi.
2. **Issue with NaN Readings** : After updating `calibrations.json`, I noticed that the Temperature and OD readings on the GUI were displaying as `NaN`. This is similar to side effects mentioned in the comments of [the same post](https://www.evolver.bio/t/evolver-wiki-software-release-2-0-0/383/24).
3. **Fixing the NaN Issue** : The solution came from updating the `config.yml` file. Specifically, I used the version from `evolver-electron v2.0.1`. After updating, the `NaN` issue was resolved, and the GUI readouts now display correctly.
_[View the full topic](https://www.evolver.bio/t/issues-with-populating-active-calibrations-in-experimental-setup-dashboard/478)._
