So the custom_script that controls the parameters allows you to set the chosen vials that are relevant for that run. Basically as the script has started running, then only those chosen vials are running.
However: is it possible to start for instance 2 vials at day 0, and then a day later start another 2-vial experiment without the first run being interrupted?
Any tips on how to arrange code for this? Drastic changes needed in the evolver.py file? Any settings of the arduino and RPi that need to be tweaked in order to minimize potential comm errors when overlapping experiments start? Is this all feasible?
I think a listener script is already implemented in the system. The Pi waits for a each change in the system (including fluidic commands), which could be from multiple scripts.
I would recommend trying to start two scripts and they check that they shouldn’t interfere with each other if the vial is “skipped” or no pump commands are sent for that vial. Both scripts will still record all vials since the machine sends the data out to any script that is connected via websockets to that IP.
So if you look at at the top, there are example commands that get sent, based on each mode of script (t-stat vs chemostat). For example, just a number represents in seconds how long that pump at that position should turn on. For the “2|4” commands, it is a pattern for when the pumps should pulse on and off for the chemostat.
You will notice that there are already “–”. That should skip that pump. Hope this helps!
