A few questions on the GUI:
- What does IN 2 do on the peristaltic pump array parameter? When I run the pump with it selected I get the following & nothing happens:
- What are the options A and B under the light parameters?
Those only work if you have the other modifications to the system, like adding LEDs for optogenetics or adding a 3rd pump array for morbidostat applications. If you don’t have your system modded to do this, it won’t do anything.
