I’m getting a lot of bubbles in my tubing. Some background:
- I fill the vials using the evolver tubing by pumping for around a minute. There will be no bubbles at this time.
- I’ll inoculate with a small amount of bacteria, and have a turbidostat mode with an upper threshold of say 0.4
- Overnight, if there are no pumping events, bubbles get introduced into the system. There are bubbles on both sides of the media input lines ( from media and to vial).
-I’m currently using massive carboys for media. These are place on the ground. But I’ve also encountered bubbles using a 1 L media bottle on the benchtop level. - One media carboy is attached to 5 vials.
This bubbles can be a bit problematic. I have phage + bacteria in my system in a turbidostat mode. Sometimes there are long periods - like 50 hours ( where the phage has killed bacteria, and bacteria is evolving) with no pumping events. Bubbles can be introduced here. When a pumping event is triggered, it will just pump air instead of media.
I know the turbidostat mode has code that protects the system somewhat from bubbles, triggering additional dilutions if needed. However, multiple dilutions are not ideal and can lead to diluting past the lower threshold. In a chemostat regime, bubbles would be more problematic as the dilution rate would in fact be much lower than expected.
Are there any ways to reduce the amount of bubbles introduced into the system? Does the peristaltic pump introduce some bubbles?
