Recently one of our eVOVLERs had a major leak resulting in fluid entering the ribbon cable ports for two vials. We have tested the smart sleeves and ribbon cables and found them to be working fine, but the port itself is the issue. We want to remove the damaged port and replace it with a new one, however it seems that the ports are soldered in a way which makes it difficult to remove. Does anyone know the best way to replace these ports?
Thank you,
Ananya
