Hi, I am now planning a ePACE system setup using eVOLVER.
However, there is one question in this regard.
The PACE system requires two major types of bio-reactors.
The first is a ‘MAIN reactor’ that causes infection and reproduction by phage, which corresponds to eVOLVER’s ‘smart sleeve unit’.
But the other important thing is the ‘host cell reactor’, where phages do not exist and only e.coli is cultured.
In the MAIN reactor, e.coli is infected and died, and phage is reproduced. Because this cycle is very short, about 10 minutes, e.coli cannot survive.
Therefore, fresh e.coli hosts must be continuously supplied from the ‘host cell reactor’ to ‘MAIN reactor’.
However, only 16 MAIN reactors exist in eVOLVER which means ‘smart sleeve unit’, but the host cell reactor does not seem to exist.
Of course, there may be a way to use one or two smart sleeve unit as a host cell reactor.
However, since phage’s infection cycle is faster than e.coli’s division rate, the capacity of the host cell reactor should be greater than that of the MAIN reactor
However, all smart sleep units of eVOLVER are designed with the same capacity.
How can I solve this problem?
Could i run PACE system on eVOLVER?
I think I should make a additional host cell reactor. But what worries me is that I don’t know much about mechanical engineering and programming.
Therefore, is it possible to make a host cell bioreactor of about 100ml using sensors and pumps that exist in eVOLVER? (At the expense of one of the 16 smart sleeve units)
I would appreciate it if you could give me your opinion on this.
Thanks
-Solved.
David Liu make one of sleeve to host cell reactor. three fold-of volume of MAIN reactor
