Hi again,
Here are those two things:
- Output log files on the eVOLVER as I try to run the pumps from the GUI. (I sent a command for INF(1) for all 16 vials to run for 5 seconds.)
- Contents of conf.yml file
acknowledge_char: a
broadcast_timing: 20
calibration: calibration.json
calibrations_directory: calibrations
data_response_char: b
device: evolver-config.json
echo_response_char: e
evolver_ip: 128.119.128.140
experimental_params:
lxml:
fields_expected_incoming: 17
fields_expected_outgoing: 17
recurring: false
value: ['4095', '4095', '4095', '4095', '4095', '4095', '4095', '4095', '4095',
'4095', '4095', '4095', '4095', '4095', '4095', '4095']
od_135: {fields_expected_incoming: 17, fields_expected_outgoing: 2, recurring: true,
value: '1000'}
od_90: {fields_expected_incoming: 17, fields_expected_outgoing: 2, recurring: true,
value: '1000'}
od_led:
recurring: true
pump:
fields_expected_incoming: 49
fields_expected_outgoing: 49
recurring: false
value: ['5', '5', '5', '5', '5', '5', '5', '5', '5', '5', '5', '5', '5', '5',
'5', '5', --, --, --, --, --, --, --, --, --, --, --, --, --, --, --, --, --,
stir:
recurring: true
value: ['9', '9', '9', '9', '9', '9', '9', '9', '9', '9', '9', '9', '9', '9',
'9', '9']
temp:
recurring: true
value: ['1640', '1632', '1635', '1651', '1644', '1642', '1634', '1642', '1636',
'1636', '1640', '1640', '1640', '1631', '1637', '1624']
fitted_data_directory: fittedCal
pump:
recurring: false
stir:
recurring: true
'9', '9']
temp:
recurring: true
immediate_command_char: i
num_sleeves: 16
od_calibration_directory: od
port: 8081
raw_data_directory: rawCal
recurring_command_char: r
serial_baudrate: 9600
serial_delay: 0.5
serial_end_incoming: end
serial_end_outgoing: _!
serial_port: /dev/ttyAMA0
serial_timeout: 1
temp_calibration_directory: temp
Thank you so much for your help!!
