Vial Cap threads
Hi, are any details about the Vial Cap thread size/pitch available? When I 3D print the vial the threads are a bit rough due to supports and I would like to get a tap I can use to clean them out for a better fit.
Hi Antonio, you can find the thread pitch in the solidworks file, but you’ll probably be hard pressed to find or create a tool to clean out the threads. Your best bet is to adjust the print settings. We order our lids from hubs.com (nylon PA12 SLS, white, 100um layer height default, with vapor smoothing if glueing other parts into it). SLS is nice because it doesn’t require supports, and nylon is durable in the autoclave.
