Stuck with DPU installation
I’m stuck at step 9: DPU Installation | eVOLVER
What should I do?
Yeah this is the issue with using Windows for coding. Always more complicated and bespoke.
Just checking did you install python 3.9? Type in the command “py -0” to list all versions
I have both 3.9 and 3.13 on this PC.
I made it one step further by doing the following: open Windows Powershell as admiistrator and prompt this: Set-ExecutionPolicy -Scope CurrentUser -ExecutionPolicy RemoteSigned. Then restarted Powershell and was able to install dependencies from poetry.
However, there was one final error that I don’t understand: (I changed the directory from ‘dpu 2.0.2’ (as downloaded) to just ‘dpu’, but still no change)
I have recently started using the Evolver and remember using this "poetry install --no-root
" when I had similar issues.
