Hi, I recently rebuilt the evolver with the updated 5.2 vial holder design, and then performed temp and OD calibrations afterward. I have been able to use the updated temp calibration, but have not been able to load the OD calibration. When I attempt to load it via the command line, it never completes. When I interrupt the command line after a while, it always lists line 302 in the Calibrate script as the location. Any help troubleshooting this would be greatly appreciated!
I would try quotes around the names since the extra spaces in the name gets misinterpreted on the command line:
py calibration\calibrate.py -a 169.254.130.102 -n "ODCal-2024-10-08 12:18:11" -t sigmoid -f "ODCal-2024-10-08 12:18:11 135" -p od_135
Thank you! Adding quotes and changing to OD_90 seemed to have worked. A followup question, is there a way to remove older calibration files from the evolver?
There is an old post about it here:
