I wanted to make a sheet metal shield for the evolver that should block out nearby sources of electrical and IR noise, as well as serving as a splash shield. Are there technical drawings for the placement of the vials for the evolver? I can find the splash shield pdf, but I can’t calibrate that without knowing one of the dimensions
Thanks,
Vincent
I’m also curious: could it be that I noticed some eVOLVER images have a black (metal) casing around the smart sleeves instead of an acrylic splash shield? Any files to make that?
I know they can purchased from fynch but not sure if the files for enclosures are available
Thanks for the reply! I already figured out that the black casing is simply just black acrylic and not metal. We ordered the splash box locally at a laser-cutting company using the provided files on GitHub.
I also made this mini protocol for the acrylic splash guard
