I am doing a fresh OD calibration, and ran into this code error at the end. It looks like matplotlib cannot find a cycler module, perhaps when trying to plot the calibration result? I noticed on the github that python 3.6 may be recommended for the calibration script, and I am using python 3.8. Could that be part of the problem?
I wanted to ask before going too far and causing myself dependency versionitis. This is the first time I have calibrated on this particular PC, so it could be related to the installation.
Thank you Zack! I ran the setup script a few months back when I was setting up this PC. Should I run the setup script again? I got this from installing the cycler:
Yeah just try installing all the dependencies it’s asking for. If you could let me know what all it made you install I can try to figure out why the installation script didn’t work.
