Hi. Which shields do you use for the eVOLVER? I don’t see a particular manufacturer listed in documentation and I’m wondering if mine is causing problems.
Hello!
Did you ever get a reply? I’m searching for the correct shield for the motherboard and for the raspberry pi.
Hi Eduarda,
This one should work for the raspberry pi, just make sure you do not populate the 120 ohm resistor between the A and B pins.
