Question from User:
eVOLVER wouldn’t adjust the temperature to 33C even when I changed it in custom_script. I had to manually change it to set different temperatures.
Question from User:
Brief Response:
Generally, the temperature gets updated based on what is written on the temp_config files (in the same file directory structure as the OD and temp data). The script interprets the last value that was written there and updates the vials accordingly. If for whatever reasons there are issues with temperature updates, first thing to check is if the temp_config file is properly updated after the first measurement or two (might take one measurement cycle to update).
in More Detail:
The temperatures initially get written in the config file with this code block (from custom_script.py). This code segment basically takes whatever values you enter in custom script and writes them into temp_config:
if (len(temp_config) is 2): #set temp at the beginning of the experiment, can clone for subsequent temp changes
if np.isscalar(temp_input):
temp_val = temp_input
else:
temp_val = temp_input[x]
text_file = open(tempconfig_path,"a+")
text_file.write("{0},{1}\n".format(elapsed_time, temp_val))
text_file.close()
Consequently, another segment of code (in eVOLVER_module.py) updates the eVOLVER with the appropriate changes:
temps = []
for x in vials:
file_path = "{0}/{1}/temp_config/vial{2}_tempconfig.txt".format(save_path,exp_name,x)
temp_set_data = np.genfromtxt(file_path, delimiter=',')
temp_set = temp_set_data[len(temp_set_data)-1][1]
temp_set = int((temp_set - temp_cal[1][x])/temp_cal[0][x])
temps.append(temp_set)
try:
temp_data[x] = (float(temp_data[x]) * temp_cal[0][x]) + temp_cal[1][x]
except ValueError:
print("Temp Read Error")
If the value is different than what it was in the past, then update the evolver again.
if not temps == current_temps:
MESSAGE = list(temps)
command = {'param':'temp', 'message':MESSAGE}
dpu_evolver_ns.emit('command', command, namespace='/dpu-evolver')
current_temps = temps
Hope this helps. Please let me know if this solves the issues.
Adding to this, the code at the moment does not write to temp_config every iteration - it only will write to it at the start. You should modify custom_script.py to write out to temp_config as shown above when you want to change the temperature mid experiment.@bgwong, let’s talk about simplifying this - I think it makes more sense to have a call out to the eVOLVER_module to handle all the logic around temperature changing/logging. The files shouldn’t really be getting modified or looked at in custom_script.py. I think a similar thing happens for OD_set. I’ll add some issues on github.
Thanks for the response. I’ll check this when I start the next experiment. The problem was that even when I modified the temperature in custom_script.py before starting the experiment it didn’t update the temperature for some reason.
